Replacing newel base with bigger size
31 Aug 2008
Devon
Sorry MODS I post my original in the wrong section - woodwork. Can a mod please delete that thread and keep this one? Ta
We live in a 1980's house and we are trying to replace our horrible 80's balusters with the Richard Burbage Fusion range.
Only problem is we have a newel base post which is 67mm but the newel base needed for the fusion range is 82mm. the original newel base goes right through the floor into the kitchen. The upstairs floor is tongue & groove chipboard which goes UNDER the walls so we can't pull it up.
Trying to get this newel base out is a nightmare. It won't budge. Any tips? I can provide phots if needed.
Shiv
the newel post is likely to have the stair stringer and maybe a tread or two, glued and jointed into the base.
it is possible to connect newels together by forming a male dowel on the new post and a female receiving hole to the existing newel post.
this would mean sawing off the existing post at a suitable height. whether this is appropriate is another matter as the location of the cut may deem this method unsuitable.
