- Joined
- 8 Sep 2015
- Messages
- 23
- Reaction score
- 0
- Country
I started discussing this in a thread i had on gas fires but i don't want one thread to go all over the place so i'll ask this here.
Basically the main radiator in the living room (single convector) we will want to be replacing so that it is at least a double panel convector. Double panel double convector may have it sticking out from the wall a little far & i don't know - it may be overkill for the room...
7mtr long, 3.5mtr wide, 2.5mtr high.
There is also another small (950mmx600mm) double panel convector rad in the opposite corner.
Anyway, measuring the length of the main radiator, it is 1750mm long. Looking in Wickes, the closest is 1800mm, but surely you'd then end up bending the flimsy 10mm copper pipes coming through the floor?
Like i said, i had only just started talking about it elsewhere, so i'll quote the questions i was asked & answer them here...
* The pipes go to both sides of the rad
* The floor below is timber. The floor will also be getting renewed. The guys doing the damp proofing job (& renewing floor) said they can remove radiators themselves, but i don't think they're qualified when it comes to getting too technical with plumbing.
* The rads in place at the moment have those TRVs on one end.
I don't know whether it'd be better going 1600mm or 1800mm. Can't a plumber just weld on to the existing pipe coming through the boards?
I imagine it'd be easier to make the piping extend to fit a smaller 1600mm than it would be to do god knows what to make it fit a longer 1800mm?
But you plumbing guys must've faced this plenty of times, so what do you do?
FiremanT said:do both pipes go to one side, or one to each?
Is the floor below solid or timber?
If timber you might be able to lift boards and adjust pipes
Myson do imoerial rads but they do not correspond exactly, but might be easier to adjust pipes to:
http://www.myson.co.uk/products/premier_he.asp#tabbed-2
