I'm replacing my old PIR sensor (which has broken) with a new one.
The cable is 2 c+e. The new PIR sensor has a N, E, L & L1 connections. Tried connecting the cable via the L, but the PIR and lights didn't work. Today, I connected the live wire to the L1 and still seems not to work (although it is daytime).
To complicate matters further - there is a switch in the kitchen that allows the outside lights to be turned on continuously; even though there was no switched live wired into the old PIR? This switch now doesn't work either.
My question is (and forgive my ignorance), do I need to connect the L and L1 contacts in the PIR with a piece of wire to make this work?
All thoughts gratefully received.
