replacing scantronic 9600 with galaxy 48
3 Jan 2014
Middlesbrough
Hi all
got the task soon of helping out a family member
they've got a Scantronic 9600 from 1991 which has been fantastically reliable until the last month or so
started off with the Panic Alarm triggering, PA button not pushed and refused to reset even with the zone looped out, hence me programming it as not used for them
last night at 4am, alarm unset, a tamper alarm triggered on zone 9, then tamper zone 10, 11 etc, looped it all out for them and it still won't reset
whilst i was there, it randomly went into full alarm, not responding to the keypad etc once it did it stated "watchdog fault" in the log
anyway, i've got a brand new never used Galaxy 48 which i'm going to fit for them
i'm well aware i'll have to fit resistors to all devices and i have installed a galaxy before but this is a large system
does anyone have any tips or advice on this upgrade?
namely the smoke detectors, there's 8 in total split between 2 zones which i'm concerned about, might it be worth fitting a RIO where the junction box is so they can be on their own zones?
many thanks in advance
they're Menvier M12's i believe and a could of Texecom's
variety of ages, all seem to work fine
not much of a job i'm looking forward to
Personally I would fit a texecom 48 ….probably much quicker as you wouldn’t need to fit any resistors and more flexible…
I would do it properly and split the devices one per zone. RIOs are cheap. Also, assuming it's a Dimension 48 and not the obsolete G3-48. Ensure the Dimension is at the latest 7.04 firmware which has been stable for years now. If not, the PCB can be updated by SPI key (£30) or serial lead.
i shall be doing it properly don't worry
i must admit i'm not sure, i think it's a Dimension 48, as it just says "Galaxy 48" on the end station
it's running V6.9, is it easy to update it?
i must admit i don't have any cables to connect a PC to the panel
The Dimension panel will have Galaxy 48 on the label. The older G3 has 3-48.
To update with an SPI key, you just plug in the pre-loaded key to the panel connector and use menu 71 to load the new firmware file. The SPI keys are available on eBay for around £30. You can also use the key to store the panel config once you've programmed it.
To update with serial lead you need a Galaxy A234 lead and a USB to serial RS232 D-type converter. The lead cost from securitywarehouse is £24 + delivery. You also need the USB RS232 lead normally around £10. There is a Windows Honeywell flash program to load a firmware file.
is it worth upgrading it from it's current firmware?
albeit the only issue i can see is they're wanting it putting in on Wednesday, don't like leaving the house without an alarm
is it possible to upgrade it after installation?
thanks
It's worth getting the latest with all the bug fixes. Firmware 6.9X goes back 10 years. If you fit on Wednesday, you can always plug in the SPI key later and save the config to the key, flash the firmware using the key, then restore the saved config.
fantastic thank you
didn't realise it would save the current config
i'll write everything down regardless
went for a look today, before i get started
aye, gonna be a job and a half i reckon, nothing labelled in the panel etc but should be do able
is there a way to have 2 seperate full sets? they have cats which sometimes have the run of the house
There's full set and part set as standard. After that, you can assign groups and have a codes that set two groups and codes that set one area. Or you can have single codes that has the choice of selecting the group to set. Many ways to achieve the same thing. Things can soon get complex.
Thank you much appreciated
Been doing some research and from using them previously I’m aware it’s not possible to have the entry timer on keypad only
Now they like to use the alarm overnight, and there’s an extension speaker right by the bedroom door
What would be the best suggestion to make the part set entry timer on the keypad only?
I’d like it personally if I could still have the speakers chime when the front door is open and sound in alarm/fault/tamper etc but not part entry
The way I normally configure for domestic is for the speaker (99) output as strobe or siren and use the keypad for entry / exit / chime tones - setting each keypad volume to suit. You really don't want the speaker doing chimes when someone comes home from a night out and others are in their beds at 2am. If you have the speaker set as the default horn, you also get a loud double beep on unset which is too loud for domestic.
I also program the virtual keypad button b as silent part set no code. You could do that with the physical keypad to make night setting easier - depends on the install
thanks for the replies, due to illness i will be doing it on monday
one last quick thing, can i set 1 zone not to use resistors but a basic N/C? it's a flush door contact with zero slack on the cable
i will figure out a way to pop resistors in if not
thanks
Yes each zone is fully programmable. Just set the zone resistance to NC for that zone.
