It's worth noting it appears your new switches are plastic with a clip on metal cover. Though it could be argued the plastic surround of the new switch does double insulate it, the very presence of that earth terminal tells us it MUST be earthed
Yea they must. That plastic is just glued to the back of the metal plate. It doesn't cover all of the metal, and from reading the BG literature, it is just there to stop the plate absorbing any moisture from the plaster
Thanks guys. I will take the switches off and put the old ones back on (or buy some new plastic ones). So effectively the old metal switches that were put on by the previous owner were also a hazard?
I'd love to get it all earthed, but I can't afford all that at the moment.
I suspect you mean you can see earth wires connected to the boxes/switches. Given what you have found, I would advise not trusting your life to them being functional.
Please do not start down the route of trying to do this just by blindly following instructions to put-this-wire-in-that-hole without actually understanding why.
Update: I took off a couple of the ceiling roses that haven't been replaced since I moved in and there is all manner of weird stuff going on that I don't understand. Decided to call in a professional to take a look as it's getting well above my pay grade.
