Hi Guys,
As I work through our old 1930's house, I also plan on lifting all the old floor boards upstairs and replacing this with larger panels. Two reasons, one is the noise we currently have when walkign around upstairs and the other is that I thought of maybe being able to use the upstairs boards to carry through the downstairs when we get aroud to doing an extension. This will hopefully keep the same look throughout.
What is the best to replace them with. I've seen the large tongue and groove chip board panels at wickes or B&Q, about the same size as a piece of plaster board. Is this best or should it be an mdf panel or somethign else?
Also, can I put some roof insulation in in the cavity between the downstairs ceiling and upstairs flooring? Both for sound and insulation? Just feel that I may as well do this all now while I can.
Lastly, on lifting the upstairs carpet to see the floor boards, they appear to simply be dirty pieces of old pine with a green tinge to them which I assume is a treatment. Is this all that traditional floor boards are? Pine, that is sanded and varnished?
