1. Most Important - floor structure (joists for me)
Make sure the floor deflection at mid span point is 1mm under a two fat bloke load. Pretty simple to do just hand a plumb line to just touch the floor then load it and see what happens. If, as with most standard timber floors it sags a bit then I suggest you sort this out by one or more of
(a) doubling up joists,
(b) Fitting bigger joists
(c) breaking the span by adding a mid-span suport
Note that fitting a sensible thickness of plywood (18mm or more) will also reduce the floor deflection if the plywood is fitted correctly (see later)
2. plywood
Go direct onto the joists with WBP (now called something line EN636-3s). Seal the edges before fitting. Thickness should be minimum of 18mm for 400 centres.
When fixing the plywood screw AND glue. This may sound a bit mad but it will dramatically improve the structural aspects of the floor. Screws want to be decent size, I would run with at least 70mm a nice fat size 6 head. Screws MUST repeat MUST be either stainless steel or ceramic coated to ensure they don't corrode and cause tile blow.
3. Tile substrate
Many like to run with a cement based board over the plywood. If you can afford this its a very sensible way to go. For a wet-room this is an absolute definate (plus full tanking).
If you don't put down a cement board you need to make sure the adhesive you use is compatible direct to plywood.
4. Tile adhesive -
Simple - Go for BAL or MAPEI, and you MUST ensure you use the latex additive to get maximum tolerance to movement.
5. Consider getting a pro tiler in
Oh BTW, while your floor is up you will definatley want to insulate between joists if you are on a ground floor.
Enjoy
2. plywood
3. Tile substrate
4. Tile adhesive -
Enjoy
