Replacing This Part (photo's Included) Radiator Tail?
26 Nov 2004
I'm trying to find an new one of these without hacking the new pipework about again :evil: Doesn't need to have a drain off, this one pictured has a slight crack on the drain off cap :( Only noticed after id modified all the pipework feeding the radiator when I fitted a new radiator in the room the other side of the wall.
Anyone with any ideas where I can get one, was looking on the screwfix website but can only see a 50mm one.
Thanks in advance again.
I was thinking about just using some chromed or copper pipe but unsure how to go about doing this (union wise)
thanks for the speedy replies chaps! What do you mean by a 15mm boiler?
Why not just get an extended rad tail, they are a bit longer that the norm and would fit in a treat, or get a new one like you have, plumb centre will sort you out.
You might have to buy a whole new valve but just replace whats needed.
using a 15mm straight and a little copper pipe would do the job but would look a bit unsightly.
