Replastering Chimney Questions
lay on with poly float (2 coats) weird i know but it's apparently the way to do it, goes on flatter, sure you could do ok with a normal trowel though.
scour (like rubbing up, circular motions to get it flat) with cross grain float (soak in water for an hour prior) to bring fat out & trowel twice to remove fat, 1 in each hand, scour with left then trowel it off with right.
brush diagonally to remove glaze once trowelling finished with damp brush
probably best to try some on a piece of board first
Blimey TM, all very informative & impressive; you been on another course :LOL:
me neither to be honest mate, they contacted me out of the blue last year, they have a place near cheltenham, process their own lime putty but run small training courses so thought i'd give it a go and add some extra info to my knowledge bank.
Did i mention i was a DIY plasterer and a bumbling fool compared to you professionals...... and this sound a little bit out of my league, but what the hell it's my house so i'm going to give this ago.
TM: you say i need to "soak in water for an hour prior to bring fat out" at the risk of sounding like a fool is this the wall i need to soak?? and if so do i just use a spray bottle to keep it wet or are we talking soaking wet?? is that what you mean or have i lost track completely.
Oh!! and what does bringing the fat out mean?
Cheers
Hi PULLMYFINGER, I've been reading your threads as I am about to tackle the exact same job as you and I hope to install a wood buner too if it's not too expensive. What did you do i the end? Can you share your tips and experience, the products you used please? Cheers :)
