I have a 1930's red brick house which is in need of repointing...
It looks like someone has touched it up prior to me owning the house but this is only a few mm deep, hasn't stuck properly, and regularly drops out. I'm looking to grind out the cement to a decent depth and repoint completely.
At the moment I'm proposing buying something like the following:
- http://www.screwfix.com/p/mortar-rake-8-x-40mm/31307
- http://www.screwfix.com/p/roughneck-brick-mortar-gun/67965
Are the mortar rake attachments for angle grinders good enough and easy enough to use for a DIY job? I see they come in 40mm lengths (and also 100mm for removing bricks completely) but I'm guessing I don't want to grind out that much cement? I was thinking probably 10-20mm (depending on how deep I have to go to reach cement that's still solid?
What cement mix should I go for? I presume I'll need to add some plasticiser if I'm using a mortar gun like the above? I'm expecting a bit of trial and error to get an appropriate mix for gunning, but want to make sure I'm starting in the right direction!
