My house was constructed is a three-bedroom one, with a kitchen in the ground floor, three bedrooms and a bathroom I the first floor. The house is central heated with a 5-year boiler in the ground kitchen, an immersion heater and a shower pump in the first floor, and a water tank in the loft.
I would like to extend the house into the loft, and add 2 bedrooms and a bathroom. If possible I would like to remove unnecessary appliances/the water tanks to create space. I need advice:
1 – Is the immersion heater essential? Could an efficient boiler be sufficient to run 2 bathrooms?
2 – As far as I understand the large tank supplies the immersion heater and the small tank the central heating system. Are they essential or can they be removed?
3 – If there is a shower pump that can service two showers? If I move the immersion heater to the loft, where should the shower pump be placed if the bathrooms are one in the loft and the other in the first floor?
4 – Could you please suggest a boiler, immersion heater if one is essential and pump or pumps?
5 – I will also have to change the fuse box. Will any of the above require additional fuse switches?
Thank you in advance for your help
