rescrewing sockets a pain!
29 Dec 2009
Wiltshire
Ive just unscrewed some electrical sockets and unwired them to fit some plate covers behind to hide tile gaps.
Now i am having massive issues lining up the screws to put the socket back on. I get one in but cannot get the second to line up.
So frustrating. Any advice?
Not really any great advice. The cables are a bit springy and can push the sockets out of true. Little annoying but not a lot you can do other than make sure they are aligned when trying to screw. Best way is probably to push both screws flush into the socket, then you have a little gap between the socket and the back box, so you can peer round and get one lined up. Put it in a few turns, until it bites and then do the same around the other side.
You can only like one up. Once it catches and is screwed there is no gap to line the other up.
God.knows how they did it when fitting it. I think I need konger screws.
The finger plates look rubbish. Any advice on how to clean up the socket edges where I tiled? There are slight gaps in the tile. Calk or silicone?
I have found using one of the LED headlights can be a great help in lining up the second screw. Shine through the hole and you can see the lug behind, line up plate and fit screw.:cool:
Are you sure the tile has been cut correctly to allow the socket to sit in the correct position?
YES.
Longer screws IF you need them.
Start putting the screw in the 'adjustable, slidy' box lug first, then put the screw in the fixed lug.
(Assuming you have this arrangement of course.)
Then longer screws are needed.
Practice. Some screws are better than others as well - some have a "pip" on the end that helps get it started, otherwise they can be tricky. But definitely one of those "practice makes it easy" things.
Do you mean the tiles have been cut with too big a hole, so when the socket is fitted there is a gap ? If so then there isn't an easy and neat solution other than to remove the offending tiles and cut new ones with the right size holes :rolleyes: You'll often find sockets with clearly visible caulking round the outside where the decorator has bodged across the gap - hard to criticise the decorator for having to bodge someone else's cockup.
