Hi all,
I'm in the process of buying a house. I went for a second viewing at the weekend and essentially performed our own survey. I was surprised to see that the electrics were all in conduit. There was conduit visible up from the consumer unit and the lighting radial in the loft was seen to be in conduit. As a 1950s house, I understand this is not unusual, and it would have originally had VRI cable running through it. This is a well maintained house, I'm fairly confident that it will have been rewired at some point. However I'm seeking a little more confidence. My question to you is, as the house has a 17th edition CU, is this a good indicator that that the VRI cables would have been replaced long ago, otherwise any sparky worth his salt wouldn't have undertaken a CU swap?
Thanks,
Sulley
Thanks,
Sulley
