Went to a defective response today. Fan runs, no ignition.
Checked inlet pressure to see if gas valve was opening to find it dropped to 5.8mB. Measured it from the test point on the pipe aswell and got the same reading.
When checking the working pressure at the meter. Standing pressure was 23.9mB and didnt drop at all when gas valve opened. It did however drop to the correct 21.5mB when checking the gas hob.
This is only a recent occuring problem. If its not a govner fault has anyone know pipes to block somehow.
The pipe is definatly undersized with about a mtr 15mm visable although it does come off the mtr in 3/4.
any advice would be great. For the time being i can only recommend a new gas run.
