the burners, electrodes are the same!! the burner is slightly different as it has a cap on the top thats all, our minimiser is a condensing boiler, but we did make a response that is also a condensing boiler, the response SE, the heat exchangers are the same on the response SE and the minimiser, but different on the response SE and response 120,100, 80. i hope this helps solve the issue, im privilaged to know this as i work at ideal boilers as an engineer.
