I am currently building a block retaining wall around 700mm high so that I can level my sloping lawn. I have set the footing and am now looking to start on the first course which will be using 7.3N 100mm concrete blocks laid flat. I need some advice on the best mortar mix to use and and some research has led me to a 3:1 mix of builders sand to cement with a plasticizer. Is this an ideal ratio and would the mix differ below ground to above?
I'm also planning to install a DPC and add weep holes every 500mm. Should the DPC be placed on the first course of bricks above ground and is it better to have the Weep holes above or below this?
Thanks in advance!
Chris
Thanks in advance!
Chris
