Retrofit insulation to internal wall
13 Dec 2022
My home should have had a tandem garage, however the owners from any years ago extended the kitchen into the back part of the garage and also added a utility.
The utility has general items, washer/dryer/boiler but was never fitted with a radiator. This basically means the utility can be treated as outside.
The door from the kitchen extension to the utility is a standard internal door, and it’s not air sealed so does let in a lot of draughts but we are going to get this replaced this year with a Upvc door.
The wall separating the kitchen extension and utility is standard stud wall, however noticed walls are very cold. After removing the light switch and back box I can see that there is no insulation.
Is there an easy way to go about blowing in insulation/balls without having to remove all the plasterboard?
Just take the plasterboards off on the utility side, insulate and reboard. If it's being treated as 'outside' do you really care what it looks like?
