I'd be grateful if anyone can give me advice on the following problem.
In 2001 I got planning permission to do some work to my flat, which involved removing a pitched roof above my kitchen, replacing half of it with a glazed roof and the other half was strengthened and flattened, and covered with asphalt, and I had an existing window enlarged into a doorway (the idea being you can have access to the flat bit so you can clean and maintain the glass section).
The work was all completed according to all permissions etc. However I've realised now (as I'm about to sell the flat) that somehow Building Control didn't issue a final certificate of inspection in 2001. I've spoken to them and they confirm they didn't make a final inspection.
My questions are these: obviously I'll have to get them back to give me the final certificate in order to sell the flat but I expect building reqs may have changed to some extent since 2001. Can they issue a certificate based on the reqs as they were when permission was granted or will they insist on any modifications post-2001?
Secondly, I've added a layer of wooden decking to the flat asphalt roof, just to protect it really and make it easier to walk on. That wasn't on the original plan. Will Building Control spot this and refuse the certificate or should I just remove it before they visit?
cheers
prospect
cheers
prospect
