Thanks for the supporttotally agree with the last post. but this whole post has been confusing!
My impression is that many posters do not bother reading the whole topic but just the last post. A bit like butting in to a conversation.
Is there any possibility that one of the radiator returns has been teed into the HW return?The HW return is the last connection before the main return pipe -immediatley (a few inches) before the return pipe enters the boiler. I agree that it all probably sounds confusing - but these are the facts.
He was probably thinking that, if the valve on the bypass is wide open, it will act as a short cut to the CH return. You need a bypass as you have separate valves for HW and CH. What boiler do you have (make and exact model)?Someone asked whether there was a valve on the bypass. Why did you ask? Could this help in the diagnosis e.g. run the hot water with this closed?
Because the OP is still wringing his hands instead of getting on with what he has to do.Why tell the OP how to check for reverse solution when it is obvious from their first post that they do?
I take it the boiler is on one floor and the cylinder is on the floor above. So the radiator return pipe(s) will Tee into the return from the HW cylinder. Like this:The cylinder is directly above the boiler at the rear of the house and the affected radiators are at the front. I can't think why there would be any more pipework other than to/from radiators at the front.
Ah! The known unknowns and the unknown unknowns.ChrisR said:If the known facts provide no possiblility of the behaviour occurring, but it does, then those facts are NOT known!
I was thinking of a swept T installed the wrong way round, so it sweeps from cylinder to rad return instead of from rad return to boiler.Dont know what d hailsham means by a wrong tee being used a tee is a tee.
