I live in a 1930's typical west yorkshire 3 bed semi. I was told when I bought the house 5 years ago that the electrics had been completely rewired in the mid 80's when an extension was added (without any planning permission I might add but that's another story).
Anyway... The first sign I noticed that all might not be well was I came to replace a light fitting with a metal one and found two single grey cables and no earth, which was strange because all the other lights/switches all appear to be ok (well have an earth at least). This particular light was on a two way landing circuit so I think the origional wiring was probably left in place here when it was redone perhaps as it would make too much mess? Anyway I borrowed an earth from the light in the next room (yes I know slapped wrist, wrong thing to do etc etc) and jobs a good one. I also added a new light to the landing which is where I found your forums, and the invaluable help to the electrically uneducated like myself.
After reading all the advice in peoples threads and hopefully taking a little on board, I decided to investigate the state of this wiring (having a strong suspicion that the 1980's rewire was a DIY job, since everything else in the house is DIY). This is what I found so far.
[/img]
Of the 3 6A mcbs the first one runs absolutely nothing, the second one runs the lights for the 1980's extension, well at least most of it, the bathroom of the extension is on another circuit. The third one runs every other light in the original house, and for some reason the bathroom in the extension?!?!
The 16A space used to house an imersion heater that was removed when I had a combi fitted in a kitchen upgrade last summer. Hopefully it has been disconnected at the CU, but all the wiring is certainly still under the floors upstairs, should this have been removed too?
The first 32A mcb runs the extension sockets, which are easily acessable and all on a nice ring (there is however a floating FCU under the studded floor with no box or anything powering a saniflow in the extension bathroom). The final 32A mcb runs every other socket in the house except the kitchen.
The kitchen sockets are from the new proteus CU in the bottom corner, the only one with any RCD fitted.
Problems:
Sockets :- This explains the lack of sockets upstairs. Each room has 1 double socket and one in the hall, 2 of which are spurs from the others, the others appear to be on a ring but I wouldn't say for sure they're not spuring off elsewhere.
Lights :- A quick tot up and there are 1530W of lighting on one 6A mcb I'm thinking then if I switched every light on it would trip?
Clearly then from reading your advice its gonna be time for a rewire. But the original cable route from the CU now lies behind a very expensive kitchen/tiles/cooker hood/units. They then also pass up through the fully tiled (floor and walls) bathroom which was done last year. I'm therefore a little concerned at the prospect of having to rip apart the best part of 20k's work that's all under two years old if a new cable route can't be found. So (after all that) here's the questions:
-Is it time for a rewire (ok I answered that myself) but is it a must?
-Is finding a new route generally easy (best guess I know you cant be sure)
-I'm looking to sell the house in ~5 years could there be problems if sold in this condition?
-Is returning to blissfull ignorance, i.e. before finding this forum a definite no? I.e. is this inherantly dangerous.
-Generally what condition do you aim to return a property to after a rewire? I.e. No making good, wallpaperable, paintable etc.
Cheers for the help guys. I had better get saving methinks.
![cupic.jpg](http://members.aol.com/mikefear/cupic.jpg)
Problems:
