Will all plaster boards have to be removed to rewire?
I'm have new consumer unit in to replace old fuse box Been told it may require full or partial rewire.
We (tradesmen with experience) do tend to be experts at repairing the plasterboard afterwards to a broadly reasonable standard too so I`d normally expect it. Naturally any wallpaper will need repapering and painted walls repainting but the actual boards end up with not much evidence of a rewire
Buy yourself a Multitool DeWalt or Makita and use that to cut holes to run cables. Some cut circular holes but I normally cut square or rectangular at 45 degree angles into the board and the off cuts can easily be stuck back into place with minimal "making good" If it's PVC T&E shouldn't need rewiring if it tests ok.
Are the back boxes the Plasterboard plastic type? They can easily be pulled out and in some cases use the old cable as a draw.
Yep the 45 degrees cut is best if available as it makes the offcut sit just below the original for a final lick of plaster and hey good as new, almost. but nil desperandum if you have another size/shape hole. it is not that difficult to cut a bridging piece from an old offcut or new board and then apply plaster or adhesive behind it before you lightly fix the bridge in. Once the bridge has set you remove any fixing screws etc then either plaster the cavity/chase/hole to the original board and can even put small strips of offcuts to reduce amount of plaster needed. I can end up quite neat.
