My fiancee and I have naively bought a 10.8kW shower thinking "biggest is best" only to find that the old shower was only wired with 6mm cable and a 30amp fuse on the main circuit board.
I've spoken to 2 electricians who claim that to rewire for 10mm cable will require tearing up floors. OK I'm naive but I'd have thought you could attempt pulling the new cable through along the track that the 6mm currently exists.
I'd imagined attaching the 2 cables securely at the bathroom end with some overlap, using a hefty wrapping of electrical tape and a bit of manly tugging at the fusebox end.
It's a 3 floor townhouse, therefore tall and narrow, with the bathroom on the middle floor. The fusebox is downstairs in the back of the garage, above the connecting internal door so horizontal distance from the shower is no more than 10 feet.
Because the fusebox is high, the wire has less than a foot to reach the under floor space, then that 10 feet of horizontal travel and finally about 4 feet to the height of the back of the shower.
Am I naive? Surely we could attempt my method before resorting to tearing up the floor (which will involve new carpet across 3 floors of stairs and 2 small landings)?
