When buying second hand then unless you have seen something working correctly the risk can be much higher.
Still waiting for a reply about the flue configuration. If it is balanced flue, as most of the options seem to be, with a second hand boiler, the chances of getting a serviceable flue assembly are very low. A leak of the products of combustion into the combustion air duct will give you the same symptoms you have. Have you tried running the burner with the air tube removed?
If you run it without the air box on, just the fan open to the air, do you still get the same problem? If the blast tube is the problem, then you will still have high CO2. You may need to shield the intake with your hand to start the burner.
By checking the specification with the appliance manufacturer or burner manufacturer. An experienced oil technician would be able to tell by looking.It has not been mentioned but how could the OP identify if he has the correct blast tube?
I've never seen a Rhino, but have seen sales blurb. O.P has already run it without the snorkel and it is still smoking.I have never seen a "Rhino" on my travels. Who makes them ??
If it has a snorkel, pierce it and insert probe and check for vitiated air.
