- Joined
- 6 Jan 2022
- Messages
- 3
- Reaction score
- 0
- Country
I found that my oil pump on my RDB1 burner was leaking from a none servicable part
(Drive shaft)
I bought a new pump and fitted it and then got an engineer out to set it up.
He couldn’t set the pressure because as soon as the burner fires up the pressure keeps on rising and doesn’t respond to adjustment before the boiler locks out. After numerous attempts
he suggested refitting the old pump which he could adjust but obviously leaked oil.
I have read from other posts that Riello will want to test the pump before they will issue a refund? I just want to make sure my engineer knows what he’s doing before I return the pump
only to find it is ok?
(Drive shaft)
