Right angle to existing concrete fence posts
25 Jun 2023
Hi all,
I have a long and thin garden with concrete posts, concrete gravel boards and wodden fence panels running both sides.
I would like to close the bottom of my garden the same way. My only issue is that both end post are standard slotted concrete post, instead of corner posts.
I was thinking of bolting, at right angle, a 6ft concrete post to the existing end posts, would that be a good way to do it, any better way?
Many thanks!
A edge, but wanted to close it properly to stop foxes to come in.
Either dig up what’s there and replace what’s there with a corner post, but as you likely to have a part panel at one end you may be able to fix a wooden post to the existing concrete one by drilling through the concrete and rebar to fix it, although that is risky. Which leaves you with plan A.
Blup
You can buy clamps that clip and grip concrete posts, mainly to hang baskets etc.
but would also work to fit a wooden corner.
Some great ideas there, that will save me a lot of work. Thanks guys
