Does anybody know when 2.5mm flat pvc/pvc t&e started to have 1.5mm cpc rather than 1.00mm? Just checking continuity on the circuits of my house and noticed that the cpc for the socket rings seems to be 1.00mm. The very small upstairs ring is 25m at most with 3 sockets, but with spur (via 13a FCU) going into attic/bedroom with another 3 sockets (another 10-15m).
The readings are:
r1: 0.14
rn: 0.14
r2: 0.50
Even if the cpc is 1.00mm csa, the reading seems way too big at about 3.5 times the phase readings.
I'm now going to check the connections at each outlet, re-test, and if no improvement, start splitting the ring to detect any fault.
Is this the right way to go about it?
Your thoughts would be appreciated.
The readings are:
r1: 0.14
rn: 0.14
r2: 0.50
