I am a new member and have found the information on the forum regarding ring main spurs very useful. As I understand it, a spur may be added to a ring main using the same cable as the ring main (2.5mm T&E) either by teeing off the back of an existing socket or by intercepting the ring main cable using a 30A joint box and teeing from the joint box. Spurs on spurs are not permitted and the total number of spurs must not exceed the total number of sockets on the ring.
So far so good.
My question is: I believe that the current carrying capacity of 2.5mm cable is 24A so a ring can potentially carry 48A, but is fused at 30A at the consumer unit - no problem there.
If however a spur is added using a single 2.5 T&E rated at 24A then it may be possible to load the spur cable up to 26A if it is a double 13A socket. This means that the current carrying capacity of the single spur cable can be exceeded by up to 2A. If one of the newer triple sockets are fitted it may be possible to draw up to the maximum 30A of the ring and the spur cable capacity may be exceeded by up to 6A before the consumer unit fuse blows at 30A. Is this likely to cause a problem or am I incorrect in the current carrying capacity of 2.5mm T&E? I am concerned that the extra current in the spur cable will cause it to heat up and possibly ignite.
Thanks.
So far so good.
Thanks.
