Ring Main testing
AWH
23 Oct 2008
Montgomeryshire
I have a fault on a ring main, installed the ring some 2 years ago and has been working fine, now it trips after about 3o mins,
Saw a good method of finding out where problem may be posted 22.09.07, but they did not say how to check circut at the cu. Help
Care to give us a bit more info about what type of fault you are experiencing and what you are doing when you experience it, or are we supposed to guess? :wink:
It would also be useful to know what skills & experience you have, and what test equipment you own...
Sorry, forgot to say ring main keeps tripping at cu. I have limited knowledge and will have to buy test equipment. I also live in a very isolated position so need to do most DIY myself.
So how did you install a ring final test and certify it without calibrated test equipment?
You're going to need to shell out several hundred pounds to get what is needed, oh and then you'll need to learn how to use it.
Best to pay for someone who knows.
If it has happened after severe weather you'd best start with anything that could be affected by that. eg outside sockets, cabling or joints that could be damp/damaged....
