Help please! I bought a new light fitting thinking how hard can it be to fit it …. nothing in my house is simple as there are 5 wires in the ceiling rose! The blue (neutral) wire of the current light fitting appears to come off a black wire. The brown (live) wire appears to come out of another black wire. The green / yellow (earth) is attached to the fitting. There are two more red wires - they appear to go into a connector between the two blacks and separated from each of them with plastic.
The new light fitting only has a live and a neutral and an earth fitting. I am not sure if the two blacks are the live and neutral and go in those two holes? The earth seems fairly obvious. The two reds - an extra connector (4th part of the block) is provided with the light- do these go into that? Is this something to do with the ring? Advice very gratefully received!
