I wonder if anyone can give me some advice. This is a long post for what ends in a short question, but I thought that by giving the whole picture that I might get some other pointers or explanation. Sorry for the length of post.
I’m replacing our kitchen units and want to add more plug sockets while I’m at it. The CU is an old fuse box (without any spare places). There are 2 x 30A fuses, one of which is dedicated to the cooker, the other appears to power all plug sockets in the (smallish 1930s) house. Based on this I’d assumed that my sockets were all on a single ring circuit that I could add to. ‘Plan A’ was to do this myself.
However, when I tested the two live wires in a plug, with my multimeter set to ohms, (with the 30A fuse removed) I got no reading (i.e. the same resistance when touching the wires to the terminals as when not). I thus guess that it must be a radial circuit (or that the ring is broken?) (I may be missing something obvious – I get limited resistance when the fuse is replaced). I think the wires in question are 2.5 mm. There is also what looks like a 4mm cable coming from the same fuse and ending in a single plug socket (if that has any relevance). I should also say that we recently bought the house from someone who did his tiling with bluetack and other such techniques, so I’m half expecting to find something odd.
I’ve read lots of forum posts and have noted the general advice that if you can’t tell a ring circuit from a radial, you should probably call an electrician. I am, however, on a tight budget and would prefer to only get a professional in once and only to do the stuff that he needs to do. I’m thinking that if I can chase all the wires in myself, it will a) save me money, and b) allow me to get on and fit the kitchen; only calling the electrician in to hook up my ‘trailing ends’ at a more convenient time.
Does this sound at all sensible? If so, do you think 2.5mm wire with all plugs connected in a daisy chain with two trailing ends would be my best bet, or do you think 4mm wire, maybe with a dedicated run to the plug that will take the washing machine?
Any advice will be gratefully received.
Many thanks,
Isaac.
Many thanks,
Isaac.
