Here we go again. He most likely won't have 230v.They will be rated at 240V so at 230V will be lower amperage.
Anyway - 0.04A
Anyway - 0.04A
Is my maths going crazy? 240²/1500 = 38.4Ω and 230/38.4 = 5.989583 amp x 2 heaters so 11.97917 amp total so yes under 13 amp but 0.04A? think slight error there?They will be rated at 240V so at 230V will be lower amperage.
Anyway - 0.04A
A few years back although official voltage was 230 volt it was in most places 240 volt, but with micro generation that has changed, at 240 volt the inverters on a sunny day could trip out on over voltage, so now 230 volt is actually 230 volt.
You're probably not going crazy, but you appear to have missed EFLI's point ...Is my maths going crazy? 240²/1500 = 38.4Ω and 230/38.4 = 5.989583 amp x 2 heaters so 11.97917 amp total so yes under 13 amp but 0.04A? think slight error there?
Well, you always have the option of putting a 16A MCB into an enclosure.I have never understood why we can't get 16A FCU so we can use European equipment from a ring or radial, however in the main 13A is enough.
You often tell that story, but I've always found it a bit hard to believe that there were tubes (or fittings?) around which presumably would/will not work satisfactorily in many countries in mainland Europe?That makes more sense, as to voltage my old 65W fluorescent worked OK with 58W tubes for years, then it would only work for month or two, in the past volts around the 245 mark, on remeasuring dropped to 230 volt...
Agreed. Having just had a very quick look around, there seem to be some "Tiny MCB modules", designed to fit into some sort of modular enclosure, in India!If you could get a neat MCB then OK, but even the push button type fitted to reduced low voltage transformers are too long to mount in standard back box.
It is not the tubes, it is the ballast which causes the problem. Ballast rated at 220 volt would work a 58W tube when designed for a 65W tube without a problem. But a 240 volt ballast would not.You often tell that story, but I've always found it a bit hard to believe that there were tubes (or fittings?) around which presumably would/will not work satisfactorily in many countries in mainland Europe?
Kind Regards, John
Fair enough, but given the inevitable variation in supply voltages (in any country), I'm a little surprised that they did/could not make one which would usually work anywhere in Europe (and beyond!). After all, even when the UK nominal voltage was 240V, some people had supplies potentially as low as 216V.It is not the tubes, it is the ballast which causes the problem. Ballast rated at 220 volt would work a 58W tube when designed for a 65W tube without a problem. But a 240 volt ballast would not.
Fair enough. It is obviously inevitable that using a ""220V ballast", rather than a "240V" one will result in higher current.That was the problem with old magnetic ballast. Many times I have counted the fittings, with 58W fitting should be less than 0.25 amp but where 220 volt ballast used one would find a 6A MCB was tripping with 20 fittings.
