In which case you know F-all about testing ring mains
"The best method is the one your electrician wants."
Well sometimes it is, but all too often from what I have seen, it really isn't.
In which case you know F-all about testing ring mains![]()
Sorry, I just realised it was you I'd responded to in the first place!i'm sorry, that was a deliberate error, never mind![]()
the join could become open circuit leaving the OCPD over sized.
And creates the possibility for a N or L break to make the circuit into 2 radials with inadequate overload protection.Rings for me
Ring mains are single fault tolerant, keeps all the sockets working and avoids the following dangerous situation
So you're saying that there were clear signs that something was wrong and these were simply ignored.First sign of trouble was the kettle was taking longer to boil and the blue light seemed to be flickering.
You have absolutely no grounds for saying that. A high-resistance connection can always overheat, and you want to use a circuit design which will mask the presence of a high-resistance connection because you think it's a good idea to mask it.With a ring circuit that single fault would not have damaged the socket. It would have gone un-detected if no routine testing was done but it would not have created a hazard.
But they aren't, are they.the join could become open circuit leaving the OCPD over sized.
Not if the OCPD is sized to protect the cable if the ring breaks into 2 radials.
FFS.![]()
1) But they aren't.
2) They never are.
3) Have you read 433.1.5?
