I've got a funny shaped flat where most things meet at 80 or 100 degrees rather than right angles, so I'm building in lots of cupboards and things.
All going well except trying to put things on the wall to hand doors off. I need to make doorposts out of 2"x 2" or so, where one side is 10 degrees or so off. I've been trying to rip cut along the length at an angle with a circular saw, but I've only managed it once or twice. I normally get a load of smoke and a nasty jagged cut. Part of the trouble is gripping the piece as well as a guide without clamping the wood you're cutting through.
Are there any tricks I'm missing? Or is this the sort of thing you can only do in a proper workshop with a good table saw? I could try planing but I doubt I'd get it even.
Thanks.
Thanks.
