Risco Agility 2 Decomission
20 May 2024
I have one of these systems in my house, it's been here for 6 or so years without being used, no idea if it was used much before then. I don't have any of the original codes or anything, but I can see the system is at least powered as the control unit has a flashing light, and the sensors periodically show a light.
I simply want to remove the system, but I understand any "tampering" is likely to set off the siren, and I won't have the codes to disable it. Is there any pathway to removing this myself? Where do I even begin if I don't have the codes?
I could get the ladder out and take a look at the siren, but I can't even find a manual online for what it looks like inside. I don't really want to end up in the situation where I've set it off with now way to disable it.
The instruction manual can be found online along with the default codes.
The unit has a master and a dmsub engineers code, there is a fair chance a lazy installer didn’t change the sub engineers code.
post back if the codes don’t work, the manual has the reset procedures I. It also but they may not work if it’s locked.
I've searched but all I can find is the installation quick start guide, and the user manual which I already have a hard copy of.
Even if I got those codes, presumably if they don't work it will set the thing off?
EDIT: OK well the number pad appears to be dead, pressing the * button and nothing happens.
Batteries are likely to be dead for the most of the wireless system, you will probably find that the external siren coms batteries are flat but not those responsible for the sounding part, its a 2 and 3 battery split. you can press the status button on the main panel and find out what fau.lts are currently on the system.
we tend to fins when servicing if low siren battery reported removing the lid the bell sounds but it doesn't communicate with the panel.
So the status is: all zones are lost, phone line disconnected, external sounder lost, external sounder low battery.
Does the external sounder low battery status mean it's the alarm battery, or just the radio battery? Either way, I assume it's not possible for it to go off unless someone tampers with the sounder itself, so I could in theory safely take everything else out and just leave the sounder on the wall?
unplug the panel and disconnect the panels battery,
The siren is not likely to communicate with the panel but when the bell lid is removed it may still sound.
