Thanks again for the help. It is in no way a deal breaker. The whole house needs decorating anyway, and the ceilings have been over-coated with polystyrene tiles so will need taking down and re-doing, so the damp is just another item on the list. My main worry is doing something that will make it worse long term, such as a chemical DPC if one is not needed.
The kitchen seemed ok but this is at the back of the house where the ground is well below the DPC, it is the front of the house that is the worse. I noticed the ground is actually breaching the DPC on one of the surveyors photos, so that is something I can at least sort quickly. The internal brick hall wall concerns me the most as I am not sure how it can get damp (although it is connected to the front wall). Looking at the positions of the external stop-cock and drains I can't see why a pipe would run under there, but once I am in the house I can strip back the flooring and plaster and figure it out!
"there might be a 1930's pipe leaking under the floor"
what? is that supposed to be helpful advice to the OP or some random leap at trolling or simple ignorance?
Don't leave any stone unturned! I moved into a 1930s house and luckily we had a plastic pipe, but 2 neighbours (houses also renovated) still had ancient iron pipes. Plus radiators, which thankfully are not leaking, but the plumbing looks pretty old and not exactly neat and tidy. So it would probably make sense to have a look at the water pipes under the house before more expensive work.
My tip though, as always, while you're renovating, add some good insulation.
For the record can I say my comments were just a joke and not directed at anybody, the site manager wasn't really called that although the lads on site used to make the joke about him because when they asked him something he didn't always give them the answer - get it
You're confusing this thread with another - there is no contradiction in my "pipe" statement.? Perhaps you could recommend help ? perhaps you could vinndicate your point.? I do hope so ?
