OP,
You really need the Damp companies out there as soon as possible.
A thorough, full house damp survey will do your problems no end of good.
Can’t think of a worst solution .John D,
No no - the idea is that all the outside walls are plaster stripped to 1m , skirtings replaced and injections with silicone on both sides of the walls.
Jobs a good'un, and the OP deserves no less.
John D,
If it isn't a pipe leak or bad plaster; could it be a roof leak or cracked mortar leading to capillary action bringing water down the inner wall causing damp ?
If there was a drain leak (clay pipes are frequently cracked or broken) IME it is most likely where the pipe connected to the house meets the pipe in the ground, and they move differently, perhaps due to settlement, perhaps due to wartime bombing.
My guess
Is the water supply pipe in the vicinity? It may be a leak, or just condensation that's gathering on it and wicking into the wall
All pipes are surface, just a toilet cistern mounted on the wall, above the damp area, but the wall directly below is perfectly dry.
