Roof ariel
17 Nov 2005
Manchester
Not sure if this is in the right place sorry if it isn't.
I want to put a TV Ariel in my loft (Which is a bedroom) now we have an ariel and I see no trouble in cutting it and adding a splitter but what is the best way to get the wire into the actual room?
My roof is thick slate then foam then plasterboard.
Thanks in advance. :D
Is it worth the hassle considering analogue is gonna be kaput in a few years?
Can you come in via the wall, less likely to have leak problems.
Nope the wall is about 3ft away from the partition wall.
What do the experts normally do?
Thanks for your reply.
Can you not from the loft and put the cable inside the partition wall?
An expert would come along, assess the situation and follow the best route possible. It sounds to me like its one of those that needs looking at...
One think to think about is... does this room have a window?
Maybe the Frame is the access for the cable???
