- Joined
- 27 Jan 2008
- Messages
- 25,303
- Reaction score
- 2,957
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Since DAB is a different frequency to VHF you can't use the original set-up so really a non starter in a Car.
At home why it is already there on Freeview so why broadcast same digital signal on two frequencies?
Whole DAB system is waist of money.
As to standby power I will agree that "Sky" boxes use nearly as much on standby as in use. But other makes are very different and my free to air box uses so little I can't measure it with plug in power usage meter.
As to original question one has to balance the amount of metal in the air to the use of amplifiers and the more metal in the air the higher the wind resistance and the more likely it is to get a lighting strike. So a banded aerial of around 20db gain is about the maximum anyone would want to fit on a roof. OK I have seen radio hams with 9 yargi beams aimed at the moon for EME contacts but the band width is very narrow and they are not on the roof.
So to split a TV signal unless one lives under the transmitter will normally involve an active amplifier and since rubbish in gives rubbish out the closer it is to aerial the better and the mast head amp with multi outputs must be best.
However working on ones roof is not easy and often one also wants to distribute Sky and Videos from main room with same cable so fitting the amplifier in the main room with the main TV has some advantages.
There is no one size fits all and each house has to have what is best for that house and with my house I can receive TV from 4 locations and aerials are selected with as much thought to rejection as to anything else. I want English TV.
99% of the time my TV's work on analogue since I use satellite in the main and distribute signal through house and once converted from digital to analogue the aerial or LNB has no effect on signal strength.
