Roof construction
This is a photo of the roof mid replacement and there are a couple of pieces of wood from the purlins to the joists.
Hangers work with binders (those timbers across the top of the joists) to support and stabilise the whole set of joists. Normally at mid span of the ceiling joists but not necessarily, as they can go anywhere to prevent the joistls being over-spanned.
Hangers and binders are used in traditional cut roofs as woody says to keep the ceiling joist depths to a minimum. Has somebody removed the binder timber from your roof ? It is a bit odd anyway if there is a loadbearing wall under the middle of the joists.
Hi as far as I know there has nothing been removed from the roof. Can I ask what you mean by binder timber? Yeah there is a load bearing wall right under the middle of the joists. Its the wall that seperates the 2 rooms below and then separates the 2 rooms downstairs.
Cheers
A ceiling binder is a piece of timber laid across the tops (at 90 degrees to) of the ceiling joists and is there to supplement the ceiling timbers. Chunky binders can span wall to wall without support other need some help mid or 1/3rd span.
A binder would have helped under the purlin but now its been floored out I don't suppose it will matter much unless the floor is bouncy. I can't see any point in those vertical bits of timber.
Thanks for the info. The floor isn't bouncy it feels pretty solid. I've only floored the main part and not gone further than the purlins I've added a couple of photos of the binders that are under the purlins and the extra supports I've attached to the binders from the purlins.
Cheers
Those struts under the purlin, fixed like that, are supporting the purlin (or doing nothing if the purlin is self supported by the bearings) and are not doing anything to support the ceiling.
If the binder is fastened all the way along to the joists and the supports are screwed to the binder then screwed to the purlins then they are supporting the ceiling. Or is that not right?
Cheers
Cheers
I think what he's implying is that the supports should be screwed horizontally into the purlin and binder. In that way, the screws are in shear, whereas the way you have it at present is with the screws in 'pull-out' mode, in which they won't hold as much weight.
Ah right I get it I will put some longer supports in that can be fastened as your diagram shows.
Cheers
