Roof/Lead Experts - please help!
20 Nov 2010
Manchester
Morning Guys,
Hope everyone is well.
Any lead-workers about by any chance?
I have a leak (small drip) that is coming through the top bedroom bay window. After removing the cladding (from the inside) I could see a few holes in the existing flashing, indicating replacement.
The work area measures in at 3.5m x 600mm.
There is only 1 supplier that I have found who is prepared to get me custom cut of lead but the price is extortionate. The cheapest price I have found for Code 5 (6m x 600mm) is £229.25, which still, is on the high side for me.
I have a few questions:
1. Is there a cheaper and/or better alternative to Lead? If so, how reliable is it?
I have read some online articles by the Lead Association and Calderlead that state you should lay lead in lengths of 1.5m strips.
The total width I am covering is 3.2 - 3.5m.
2. Do I cut two 1.5m strips and one 0.5m strip? or is there a better way to divide/cut the lead to cover the working area? i.e. three 1.16m strips?
3. Whichever option is best in question 2, what method is the best to join the overlapping strips? - nails, screws, lead sealant or just simply hammering it down?
4. When overlapping each strip, by how far do I overlap each strip for e.g. does strip 2 need to overlap strip 1 by 100mm?
I am a complete newb and I would be extremely grateful for your help and advice.
Thank you very very much for helping
Hahaha no worries bro.
If its best to go with Code 5, I will but I really could do with some help regarding the technical questions.
Cheers mate.
Leadwork (i.e. lead rolls, burning, bossing etc) is a highly skilled craft and not a diy undertaking.
The odd flashing and apron maybe, but not a complete roof.
I think you are confusing lapping flashing (which is vertical) with joining lead on an almost horizontal roof
You can't just overlap lead in this use on a bay roof - water will get between the lap. Normally a rolled joint would be used, or perhaps a soldered joint
You may be better off getting a mod to move this thread to the roofing section, as there is a guy (Leadman, I think) who should be able to answer this in more detail
There is also the dressing around the roof perimeter to consider
Cheers mate!
That's what I was thinking originally - water getting between the laps.
Forgive me for my ignorance but what is a rolled/soldered joint? The first thing I am thinking of when reading "solder", is multiple pieces of lead being soldered at the point they join.
Would you also be able to confirm the 1.5m rule? - Does the lead for this particular case need to be cut at 1.5m lengths?
Thank you friend.
1 no not really imo
2 split it into equal sections ,eg 3x bays so you would need to wood core rolls.
3 If its flat or only has a small fall you are looking a wood roll , standing seam is possible but harder to achieve.
The only way to do it with out is by welding in a rubber expansion strip or two if diemensons require ,haven't used it in years but used to be pretty expensive
http://www.source4me.co.uk/store/store/Roofing-sundries/Flashings/Lead-Expansion-Joint/prod_170.html
4 overlap is based on the pitch of the roof and its nota option if its flat
I'm a city & guilds qualified lead roofer, LAS reg'd etc, here is my advice to you;
Get a bloody lead worker to do it, its all well and good having a go at general DIY, but were talking a lot of money on materials here, materials that need to be used to the proper standards, or they are rendered useless.
Average cost to renew a bay roof in lead = £550-£750, if thats unaffordable I suggest you consider cheaper alternatives.
Trust me, if you dont know the basics ie lappage, length codes etc, this is not a job for you to undertake!
