Got any pictures of the inside?
So we can get an idea of the room layout, in relation to the chimney.
Utterly failed to get a shot of the damp, it doesn't show up. All you see is the corner of the room 'cos the the chimney breast is in the next room. The damp patch is on one side of the chimney onwhich forms part of a the flat wall of the room. breast the oother two internal sides are dry. I'll draw a sketch and post it when I get a mo.
I've discovered today that the damp isn't coming from directly above, it's utterly dry there. If te chimney is the leak source the water must be finding it's way through the brickwork itself. I thnk that rules out a leak from where the flashing meets the tiles (although it's still entriely posible its coming in where the flashing meets the bricks.)
Obviously I don't know for sure it's coming in via the chimney but it's interesting that the three patches of damp follow a vertical line on one face of the chimey.
This isn't come at a cood time. I'm pondering some options instead of getting pros in right away for a pukka job:
1) I take a day off work and re-point chinmey as far as the DPC myself. This would be quite safe [1] 'cos I have good access from a flat roof. I might get lucky - that might fix it.
2) As one, but get a mate who's a pro to do it. Problem here is availability.
3) Live with it 'till next year and sort it properly then. It's tolerable as long as it doesn't freeze and take the whole chimney down on my head.
The downside of 1) is that I've never done any work on a roof before and know nothing about it. I weigh 18 stone, will roof tiles even take my weight? I've seen people clamber around on their roofs without doing damage... Is it fairly easy to do so without doing damage?
[1] Well it's an 8ft fall which could still be really nasty.
