Quote Jeeeezus… do you own shares in a pine forrest or something
In timber, No. Other commodities. Yes. Very many.
Quote. Whatever happened to building economically and expediently?
Went out the window 1667 when the London Building Act was introduced and even more so in 1936 with introduction of the Public Health Act. Will not mention 2010 Approved Docs introduced 1985.. Get too wound up. Possibly you are not old enough to know or remember.
Quote. Those are monster joists for a floor, let alone ceiling joists and even worse for rafters. But there's more ... putting them in a 400 centres and then having them at 4500 long, makes this an OTT roof, much too heavy, much too costly and a job that Popeye would baulk at.
Agree, monster ceiling joists and rafters, but if you was to read the post correctly and understood roofs, then you may just see the reason why they are slightly oversized. Rafters at 4500 long.. Okay, so you design roofs without overhang for facia and soffit. We do not feel BC would be very happy with rainwater running down middle of cavity, but will give it a try , and say that woody said it is good practice. OTT roof. Prove it. Do a cost on increased baulk sizes, as against omitting doubling up 4 no joists, purlin struts and wrap round purlin. and labour on purlin Weight of the roof. What’s that got to do with it? Founds will take it. A job that Popeye would baulk at. Quite apparent then woody that you have never done any joisting or heavy roof framing. As you evidently do not know the weights of timber. Will tell you 4500x50x225 weighs in at approx 26.75kg.
Quote, catlad does have a point. There are 1000's of houses with 3x2 rafters and nothing at all wrong with the roofs.
Agree. We have seen a few. Those that we have had to strengthen and take the sag and bow out of often at great expense to the house owner.
Quote. We have a bizarre situation where todays span-tables say that all these 1000's of roofs are over-spanned, and yet why aren't they all falling down or spreading?
We have not been in 1000’s of houses that have these so called 50x75 roofs, so we can not comment, we can only comment on those that we have been asked to strengthen and take the bows out of. However, we do note a lot of sagging roofs in our walkabouts. Possibly they are the ones you mention.
Quote. There is nothing wrong with 3x2's if the supports are there, but I'd agree that 4x2's tend to be the minimum spec'd nowadays, but that's probably just our laziness and wanting to get drawings passed rather than spend time calculating and proving that a 3x2 rafter roof will work
Agree span tables are well loaded and in our opinion over the top, but question is woody, how do we get BR’s approval if we do not work to span tables? Could we say that woody said 50x75 are acceptable. Your answer should have been, get a quote for half trusses with a bottom toe, then again that was not the OP question.
Regards oldun.
