I am upgrading the controls on my CH system and want advice on where to put the room thermostats.
Background: I live in a large 3-floor victorian house. I am installing a 3 channel programmer so that I can heat the 4 bedrooms separately from the ground floor and DHW. The hall and stairs right up to the top floor are heated by a radiator on the ground floor. All radiators are fitted with Thermostatic Radiator Valves except the bathroom (first floor) which is where the room stat is at the moment.
Problem: The TRVs will shut off the rads in each room when that room gets up to the desired temp. I don't want a room stat to turn off before the rooms are warm enough, but I also don't want it calling for heat when all the TRVs are closed.
I know that room stats are digital (i.e. either calling for heat, or off) whilst TRVs are analogue (i.e. the warmer they get, the less flow they allow). Should I therefore have the upstairs channel as it is (bathroom rad with no TRV and the room stat in there) and put the door-stairs stat in the main living room whilst removing the TRV from the rad in there? Or does anyone know of a better solution?
