Room thermostat change
2 Oct 2008
Berkshire
Hi All, I am going to change my Honeywell T6360B thermostat with a Wickes thermostat.
I have a potterton Suprima standard boiler (not combi), motorised valve and cylinder stat.
The Honeywell stat is wired as follows
Pin 1 Red wire
Pin 2 Blue wire
Pin 3 Yellow wire
plus an earth wire
The Wickes stat has pins 1, 2 and 3 plus an earth.
What should go where???? can someone help please.
blue to neurtal red to common yellow to call or demand whatever you want to call it. Could try the wiring diagram :!:
