yes that would be obvious less energy is used, but the point i am trying to make is the room with stat gets up to temp, boiler shuts down, but every other room might still be cold and calling for heat. And surely the boiler does not run constantly, if the return water comes back hot still i'd pursume it shuts down otherwise the water would boil? Im not disagreing i just want to understand it.[/quote]
Every time the gas valve opens you lose about 20% of unburnt gas out of the flue. You can't do anything about this it's a physics thing therefore the way to save fuel is to ensure that the boiler doesn't cycle and the way to do that ,amongst other things,is to install some sort of electrical control to control the house temp and thus the gas valve opening and closing.
Bottom line is house warm and boiler off saves money. House roasting and boiler/gas valve constantly on and off costs money or even worse house cold and boiler constantly on and off = throwing money away.
