Winston, did you miss this bit of my post ?
No, but the OP and endecotp appeared to have.
They chose to ignore it because its not important.
It has an average effective value of 12 volts but will almost certainly not be a smooth DC voltage having been produced by high frequency switching.
The various high frequency switching functions interact with each other and create instability in operation pf the various items.
As you said in your first post you need an LED driver.
You do NOT need an LED driver external to the lamps. You need a 12 volt power supply.
On the contrary, that is exactly what you need; a transformer that goes down to 20W. See my post #5.
Not necessarily - it means that one cannot be sure that a particular LED lamp will work satisfactorily with high frequency AC. The source also needs to be one whose "minimum load" is less that the total load represented by your LED lamps (as demonstrated by what happened when you restored one of the halogens).implies that the smaller Aurora "product" I linked to, will NOT help due to the high frequency switching.
So did I.. As I wrote before, if it is a "12V lamp", what it needs is a constant-voltage 12V source. "LED Driver" is ambiguous. Some would take it to mean a constant-current source - which is not what you want (and not what many people want/need).winston says I need a driver... bernard says these are already present in the lamps.
As above, a "12V LED lamp" (or any other LED lamp with a specified voltage) must have internal circuitry ("a driver") to control the current - otherwise the LED element(s) would be destroyed (by excessive current) as soon as the specified voltage was applied.winston says I need an LED driver, but bernard thinks these are in the bulbs already.
I'm at the stage where several posts imply that the products I linked to are not suitable for my application, but endecotp's posts imply it is exactly what I need.
... if it's true DC.Back to your immediate problem I suggest you look for 12 volt DC power supplies.
It happens with all sorts of SMPSUs, not just those sold for use with halogen lamps - although, as Rocky has said, it seems to be increasingly less common.No transformers have ever had a lower load limit. That only happens with SMPS used with halogen lamps.
It is NOT even a transformer, nor are any of the other devices you have linked to, they are switch mode power supplies and unsuitable for driving LEDs.
Or you could of course get a real toroidal transformer as they can run on AC or even a DC power supply.
