Use 4mm² cable then.
I suppose my first reaction (aka 'gut feeling') would be the same, but I'm not sure how rational that really is ... unless one is talking about very close to an end of a ring (and provided that appropriate cable is used if the spur is to serve more than one socket), it's not really materially different from a radial (which can 'branch' as much as one likes), is it?... And for me, spurs on a new installation is a bit poo.
...And for me, spurs on a new installation is a bit poo.
Whilst that is certainly true, if you're still talking about spurs, as I wrote, I'm not at all sure that I personally regard them as 'rough stuff'. As I said/implied, there's not really any electrical argument against it (as installed).Yeah, the regulations permit you to do all kinds of rough stuff if you are so inclined.
It is always a matter of opinion. However when you are already chasing the walls such that installing the ring is possible, then I don't see any reason to compromise.Whilst that is certainly true, if you're still talking about spurs, as I wrote, I'm not at all sure that I personally regard them as 'rough stuff'. As I said/implied, there's not really any electrical argument against it (as installed).
Agreed, but "compromise" still implies that there is something inherently wrong ('rough') about a spur, and I'm not personally convinced it is the case.It is always a matter of opinion. However when you are already chasing the walls such that installing the ring is possible, then I don't see any reason to compromise.
Without trying to sound like a patronising berk, I don't think anyone here is suggesting applying any force, or awkward bends.
A cable can be run through a 25mm box with a standard plastic socket without having to apply any force.
I wouldn't have said so, if you arrange the wires neatly as you go.That is not true, it requires a lot of force, unless your doing it on a work bench
