Hi
I am looking for good examples of how to install cables in chased out walls. Not particulalarly the route they should take more of what should be used to protect them in a brick/rendered wall that has chased out to accept the cables. I have tried 25mm oval conduit but they(25mm oval cables) seem a bit tight for two cables, and I haven't found an ideal way to secure the conduit to the wall. (apart from galvanised nails nailed at either side with the heads holding the conduit). I suppose pictures would give me the best idea so are there any sites which might show the correct way to install cables in a chased out wall.
err by the way the cable would be 2.5mm t&e.
