I've recently had a structural engineer draw up some plans for a rsj I want fitted. We're having a structural wall taken down between the kitchen and lounge. The wall is 3.4m and used to be the external wall to the house until a double storey extension was put on the side. The wall in question is a cavity wall made from standard construction.
After receiving the plans my builder has informed me that the rsj's suggested are far too large for the opening and will required more equipment and labour to fit, thus costing me more money. The drawings suggest using 2 254x146x37ub? Bolted together with steel plates welded top and bottom with the addition of 2 pillars built from engineered brick. But my builder whom has years of experience believes we'd require 2 rsj sizes of 203 without the addition of the engineered brick, and no welding of plates.
The engineer will not adjust his plans as he says everything he has calculated is correct by British structural standards. I'm a keen diyer and have renovated 1 flat and 1 house, but this job calls for experts, can anyone help? I can post drawings if required.
Thanks.
Kev
Thanks.
Kev
