You could always use ventilation to dry out damp area and it’s free.
But where do you get these from?We used some thing like this View attachment 332520they clearly worked as the water arrived in the bottom, but the best dehumidifier had to be single glazed windows with a small built in tray on the bottom of the metal frames and a hole to the outside, you could see the water running down the windows, and when the temperature dropped got some lovely frozen patterns, as a child was told painted by jack frost.
There are second hand carver heaters for sale made in the 70sThe biggest problem I had with damp was living in a caravan, the problem was we used gas for heating with no flue. Burn a hydrocarbon and the hydrogen combines with oxygen in the air to make water. So putting on the gas fire to dry the caravan simply did not work. Cure was to get electric hook up, and use a fan heater, latter caravans had a gas heater with a flue.
although all the joints have been bitchmaned with tar, it still leaks somehowYou could always use ventilation to dry out damp area and it’s free.
Put a large marquee on top .although all the joints have been bitchmaned with tar, it still leaks somehow
The mind boggles...bitchmaned
the problem is that there is a lot of wind down there and also i am trying to keep a low profilePut a large marquee on top .
Perhaps keep off the socials and just live your hermit lifestyle then?i am trying to keep a low profile
Robert Fidler style, pre-bale removal?the problem is that there is a lot of wind down there and also i am trying to keep a low profile
idiot!Perhaps keep off the socials and just live your hermit lifestyle then?
What % of the people today will remember those signs.
